I am testing the web blocking feature in Peplink Balance 580.
Blocking of categories is working fine.
But I am not able to set exemptions using either user groups or subnets.
Can someone please assist?
Regards,
Joseph
Regards,
Joseph
I just do a quick check (Firmware version 7.0.2) and the group exemption is work.
May i know what firmware you are using ?
Any NAT device between the client PC and the Peplink device that possible will NATed the client IP address ?
Which website you use for testing ?
Possible to share the network setup info for the Peplink device ?
Thank you.
Would you able to upgrade the device to latest firmware and test on the web blocking (group exemption) again ?
You can download the latest firmware by using the URL below:
