Hi guy,
A GRE tunnel can be easily set up between two L3 devices(which means the tunnel source is “tunnel source 100.67.97.200” in the following configuration, GRE tunnel is working properly ). However, after a Peplink device (1-to-1 NAT) is added into the network, the GRE tunnel can not be established, the debug message as below:
we are using Peplink B-380 with Firmware 8.0
Scenario :
L3 device01 (GRE tunnel) -----Peplink NAT ----L3 Device02 ( GRE tunnel ) (SW-c37Right)
Configuration:
- 101.36.48.200 = IP of the Device01
- 100.67.97.200 = IP of the Peplink NAT( for WAN NATing )
- 10.83.2.254 = LAN IP of the Device02 ( for LAN NATing )
- The Peplink has only default policy, and permit any any
SW-c37Right#
interface Tunnel3
ip address 10.10.23.6 255.255.255.252
keepalive 5
tunnel source 10.83.2.254
tunnel destination 101.36.48.200
tunnel path-mtu-discovery
end
SW-c37Right#sh ip int brief
Interface IP-Address OK? Method Status Protocol
Vlan20 10.83.2.254 YES NVRAM up up
Tunnel3 10.10.23.6 YES NVRAM up down
SW-c37Right#sh int tun3
Tunnel3 is up, line protocol is down
Hardware is Tunnel
Internet address is 10.10.23.6/30
MTU 17916 bytes, BW 100 Kbit, DLY 50000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation TUNNEL, loopback not set
Keepalive set (5 sec), retries 3
Tunnel source 10.83.2.254, destination 101.36.48.200
Tunnel protocol/transport GRE/IP
Key disabled, sequencing disabled
Checksumming of packets disabled
Tunnel TTL 255, Fast tunneling enabled
Path MTU Discovery, ager 10 mins, min MTU 92
Tunnel transport MTU 1476 bytes
Last input 00:54:25, output 00:00:04, output hang never
Last clearing of “show interface” counters 00:04:14
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/0 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
51 packets output, 2448 bytes, 0 underruns
0 output errors, 0 collisions, 0 interface resets
0 output buffer failures, 0 output buffers swapped out
SW-c37Right#
SW-c37Right#
*Mar 2 00:04:41.715: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:42.705: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:43.703: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:43.795: Tunnel3: GRE/IP encapsulated 10.83.2.254->101.36.48.200 (linktype=7, len=48)
*Mar 2 00:04:43.795: Tunnel3 count tx, adding 24 encap bytes
*Mar 2 00:04:44.693: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:45.699: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:46.689: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:47.696: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:48.677: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:48.803: Tunnel3: GRE/IP encapsulated 10.83.2.254->101.36.48.200 (linktype=7, len=48)
*Mar 2 00:04:48.803: Tunnel3 count tx, adding 24 encap bytes
*Mar 2 00:04:49.684: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:50.674: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:51.664: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:52.662: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:53.660: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:53.811: Tunnel3: GRE/IP encapsulated 10.83.2.254->101.36.48.200 (linktype=7, len=48)
*Mar 2 00:04:53.811: Tunnel3 count tx, adding 24 encap bytes
*Mar 2 00:04:54.659: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:55.657: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:56.647: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:57.645: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:58.651: Tunnel3: GRE/IP (PS) to decaps 101.36.48.200->10.83.2.254 (tbl=0,“default” len=80 ttl=61)
*Mar 2 00:04:58.819: Tunnel3: GRE/IP encapsulated 10.83.2.254->101.36.48.200 (linktype=7, len=48)
*Mar 2 00:04:58.819: Tunnel3 count tx, adding 24 encap bytes
Any hint/suggestion from the debug messages, thx ?
