This is about GPS Forwarding —> Report Interval (s).
Is it possible to change reporting interval all devices in one go? It is time consuming to change it for every device one at a time.
Thank you.
Thank you.
Would you think Bulk Configurator can achieve your requirement?
I had read documentation but I was worried that I will end up modifying some fields on other devices that I do not intend to.
Thank you for suggestion.
I will move this to feature request for the team to review.
Thanks.
