Google Fi Setup with MAX Transit Cat-18
I just got my Transit Cat-18 and was going to get a Google Fi sim card since I’ve heard people have had success using these in the Pepwave. However, when you go to order the BYOD sim on Google Fi’s website, it makes you select a specific phone make/model to use. So do people just order the SIM for their phone and then put it in their Pepwave or what?
I guess the bigger question is if Google Fi is IMEI locked or not.
you have to first have a voice line, then you can add additional data only lines once you have an account. The voice lines/data are for phone and are white sims, the data only are yellow sims.
