Hi Team, is there a way within the MAX series routers to set within the RSSI/signal values a specific signal strength to not allow the modem to try and reconnect to the LTE signal when it’s connected to a strong 3G signal?
Say if the RSSI value of the 3G connection is 3000 and the RSSI value of the LTE signal is only 1000. It not go up to LTE? We know there is a signal strength threshold that can be set, but we are not positive the exact behavior of that function.
If not, this is a formal feature request.
