Gmail: Sign-in attempt prevented
Device: Peplink Balance
Firmware: 6.3.0s026 build 3119
While attempting to configure Email Notification, following the steps outlined in the Peplink KB, I receive a “test failed” error whenever I click the [Send Test Notification] button:
[INFO] Try email through auto detected connection
[INFO] SMTP through SSL connected
<-] 220 smtp.gmail.com ESMTP m84sm19350740pfi.75 - gsmtp
->] EHLO balance.peplink.com
<-] 250-smtp.gmail.com at your service, [xxx.xxx.xxx.xxx]
<-] 250-SIZE 157286400
<-] 250-8BITMIME
<-] 250-AUTH LOGIN PLAIN XOAUTH2 PLAIN-CLIENTTOKEN OAUTHBEARER XOAUTH
<-] 250-ENHANCEDSTATUSCODES
<-] 250-PIPELINING
<-] 250-CHUNKING
<-] 250 SMTPUTF8
->] AUTH PLAIN WxGCqZQjnBTPDwkAeXbzXlMoRTHhdlawLseW
<-] 534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbsT
[ERROR] [sent AUTH PLAIN WxGCqZQjnBTPDwkAeXbzXlMoRTHhdlawLseW
] [result 534] [expect 235] unknown response "534-5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=HDQcxmkU
Shortly after these test failures, I received an email from Google with the following security message:
Hi Jason,
Someone just tried to sign in to your Google Account [email protected] from an app that doesn’t meet modern security standards
Is there a known workaround for this, or is there a firmware update in the works to address this issue?
Kind regards,
Jason
Hi Jason,
This is related to the gmail account security setting that allowing other application to login. For more information, please refer to the URL below:
Thank You
Thanks for the workaround!
