Get hardware usage information from Max Transit Pro Duo
Is there anyway to get the CPU load, RAM usage and current temperature for the Max Transit Pro Duo? I tried the IC2 API and I am able to fetch the CPU load but had no luck with the other two
Hi…
About temperature… This device, don’t have sensor for it.
Screenshot 2024-09-12 at 14.11.14
