Geolocation and ip problem
Hello Dears,
Can you help me with this :
1.Geolocation of appliances does not work in Cameroon. All are located in the US. Problem of identification of Cameroon IP?
2. A customer located in Douala with 1 dedicated connection with fixed IP and 4 ADSL connections Dynamic ip fiber. the address assigned to the firewall is fixed. The one on the peplink router also fixed or can be dynamic?**
thanks in advance
Hello @Ibrahim.KONE,
Have you been able to work out your two issues?
I suggest opening a support ticket with Peplink for each of your two issues, post your ticket numbers here, and when you get the solution to the problems, please let us all know.
Happy to Help,
Marcus :slight_smile:
