Hi, I have a question about the bonding technique of the SpeedFusion Engine. We have a FusionHub located in a datacenter and as remote devices one BR1-Mini and one SFE. Both units use the same SIM card provider (one SIM in the BR1 and two in the SFE).
BR1
On the FH Status → WAN Statistics the Remote connections show the correct Carrier Packet Gatway (P-GW) IP (35.158…) on “Cellular” that can be pinged.
SFE
On the FH Status → WAN Statistics the Remote connections show the correct Carrier Packet Gatway (P-GW) IP (35.158…) on “Cellular 2” that can be pinged. However it shows the internal cellular IP (10.189.5…) on “Cellular 1”. Attached some screenshots.
Can you explain me why the two IPs of Cellular 1 and Cellular 2 are different?
