Hi all,
Got a short question about the troughputs limits on different Fusionhub versions.
The maximal througput of the speedfusion connection when using fusionhub is that per peer or in total?
for instance when using the essential appliance i can make 5 speedfusion connections with 25Mbps througput.
When i for instance only have 1 speedfustion connection do i get 25Mbps throughput because i am then only using one peer or do i get 25 : 5 = 5Mbps??
Thnx!
