Hi all,
Currently testing Speedfusion between remote HD4 and central fusion hub installed in a DMZ.
Everything works perfectly well.
only one remark, it seem traffic comming from remote site to my server is natted behind the Fusion hub IP.
How can I disable this feature ?? and let real source IP arriving on my server.
(I will create a route for traffic return.)
Thx all
V.
In Network → WAN | Connection Settings click the little blue question mark icon next to the Routing Mode then unhide the IP Forwarding Option:
You can then chose IP Forwarding to disable NAT on the WAN and uncheck the “Apply NAT on Remoet Peers’ outgoing traffic” checkbox to disable NAT fully for traffic from the remote HD4.
Thx for your help.
It works perfectly.
Rgds
V.
