I have an HDMAX 4 that the firmware will not update. this is the error in IC@
(Firmware updated too many times. Update aborted. (Probably firmware ver string mismatch)) (Retry: 20)
the device event log on the HDMAX4 does not show any thing.
May I know what is the existing firmware version of HD4?
May I know which firmware version you are trying to upgrade?
May I know what is the available WAN links for the HD4?
Currently its on 7.1.1 build 3775
trying to go to 7.1.2 build 4094
the Wan ports are all 4 Sim cards
Wan 1 & Wan 2 are disabled.
Thank you
This possible relates to the WAN connection. Basically InControl2 just gives an instruction to the HD4 to download firmware and perform the upgrade. I suspect the HD4 fails to download the firmware.
You may open ticket for us to take a closer look.
