I received my new Balance 380 unit yesterday. Surprisingly I found the firmware was not upgraded.
Still it shows 5.3.12. In this no Speed fusion option.
In order to upgrade the firmware, I down loaded the configuration file and uploaded. Then I tried to upgrade the firmware option. It shows there is no up grade available.
In order to upgrade manually, I downloaded the image file of version 5.4.7. Selected file for upgrade. While the process, it shows upgrade is failed.
There should only be two files within the ZIP, one is a .bin and the other a PDF. Please confirm the firmware you are trying to upgrade to is named:
fw-b380_390_580_700_710_1350-5.4.7-build2423.bin
In your first post you mentioned it is a Balance 380, but it sounds like you have downloaded the 310/210 package instead?
I bought ZTE MF190U modem with AIRTEL service provider. It is not connection in Pepwave r with balance 380. before purchase I saw the model as MF190 is listed. Is there any way to use it with Pepwave Max700 or balance 380?
