Firmware update questions
As a new user, I’ve recently receive my SURF-SOHO MK3.
It arrived with Firmware 6.3.3 Build 1068 installed.
My question:
Is incremental firmware downloads required to reach the latest release? If so, what is the recommended sequence for upgrading the existing firmware?
Any input is greatly appreciated.
Hi Tray,
You would be able to move forward with upgrading to 8.0 on the SOHO. If you are upgrading any of the BR1 models, you will need to upgrade to 7.1.2 before upgrading to 8.0.
Thank you for the quick response
