firmware 8.3.0s213 build 5393?
Hello i just add 2 new peplink balance 20x to my organization , no problem at all
But for some reason they got updated automatically by incontrol with a firmware 8.3.0s213 build 539
what version is it ? is there hotfixes integrated ? why it got updated automatically i just look into Firmware Management i dont see that version only beta en 8.3.0 build 5315
Thanks for any info about this
Hi there,
The builds with ā€œSā€ in them are usually special builds with extra fixes. However, the next build / 8.40 should include those fixes anyway.
Cheers
Thanks Nik for answer do you think is safer to install 8.4.0 RC2 on production sites ?
thanks in advance.
I would stay with the 8.30s build and wait for the released version of 8.40.
There are still minor bugs being discovered in the RC2.
This is obviously entirely up to you - RC builds usually are stable, but unknown/new issues may arise.
