Guess what happend when i disabled USB? I ofcourse got kicked of the VPN so now i have to walk down and reboot it into the non beta firmware manually
Josipz,
I’ve seen this too. It happens when you modify any settings to do with the cellular modems. E.g. change the names, apns, MTUs, etc.
They appear to be online in the dashboard but they no longer work in the bond, and if you attempt to ping in the GUI using any of the cellular modems in question they will not work. The only way to get them working again is to reset to factory defaults or use an old version.
I logged a request about this and I was told it will be fixed the next release.
I also see this on the MAX HD2 we are trying Beta out on
No cellular in the bonding and confusingly also not picking up Wi-Fi networks either
Works on Wired WAN for me, had not tried USB yet
Ticket open 748451
