Hi All
I am brand new to the Peplink world , and have completed most of my setup , I am having troubles getting my mind around is the
“Inbound Rules”
By Default the Inbound Rules under Firewall are set to “allow all” , no problem , I get that
for example 3389 for RDP, from WAN to a secific ip internally for eg 192.168.1.25 using the standard port 3389 internally
I do have a “Server” setup on the Peplink and a “Service” transposing from and External IP to an internal computer
I can connect no problems
When I set Inbound Rules to “deny all” and
I set a rule , for 3389 for RDP, from WAN to a secific ip internally for eg 192.168.1.25 using the standard port 3389 internally (The “Server” config and “Service” config still exist)
I have set the “new” rule above the “Deny all” rule when I try and connect the the computer behind the Peplink , using the external IP, I cannot not connect , yet if I change the basic rule to “Allow All”
I can connect
What am I missing ???
I am using
Peplink Balance 310 , firmware 5.4.6. Build 1829
Robert
