Firewall rule for Peplink Balance 2500
Hello All,
Is it possible to restrict the peplink balance 2500 web admin page for specific ip that will come from outside of my network? If it is work, please suggest me the solution.
On my 310x, I believe that is configured under the local service firewall rules. The drop down for service has the Web Admin. Just pick the source you want and allow it. Then write another rule to disallow (deny) everything else directly under it.
you also need to change the system security settings to allow access to web admin from both LAN and WAN.
If you want to deny access from LAN, you will need to also add an Internal Firewall Rule to prevent such access.
if it were me, and nobody else has physical access to the router - make a LAN port an access port to a special VLan that has LAN access to the web admin. It may be a good backup plan Since you will be locking it down to a single public IP as having access.
Thanks for your suggestions. I can’t do without your help and I appreciate your suggestions.
