I have Peplink Balance One with FW : 6.3.2 build 2427
can you plan to add the below features :
— outbound
can “IP range” option be added with ability to select / define multiple ports “not a range of ports” (instead of create a rule per port/service for the same source)
the ip range (source Ip)option is not available only network option is available.
only port range is available , but multiple port selection (not in a range) isn’t available
— inbound
can you add the ability to select / define multiple ports (instead of create a rule per port/service for the same destination)
also if ip range can be available to Qos created groups , it will more simple.
thanks in advance.
