Would it be possible to add more options to the OSPF configuration options currently in Ic2.
Specifically we need to be able to set the OSPF area and ideally based on tags.
Use case -
We frequently move devices in and out of groups depending on what we need them for.
In some cases we have to do a lot of manual / direct configuration of OSPF on the devices due to the network that they are being joined into.
In an ideal world we would just have everything configured in Ic2, move the device to the correct group and change a few tags around - we do this already for the vast majority of the configuration such as firewall rules, OBP, VLANs, SF config and so on, but we are unable to set OSPF up using this method.
