Would it be possible to add a feature to cut off high latency LTE lines while loadbalancing.
I know speedfusion has this option but for some costumers speedfusion isnt possible.
Maybe this could be an extra healthcheck setting? When ping is higher then (setnumber MS) drop connection of this WAN for (X) amount of time.
I know this could cause issues with HTTPS sessions and speedfusion woudnt have that problem. But some costumers would really like this feature but cannot implement speedfusion due to numerous reasons.
Yes we did, We also explained this to the costumer. They want to have the load balanced evenly over there 4 Modems (Cards). Both protocols will not do this as they will prefer the fastest response/ lowest latency modem. They want to completely drop one connection for a X ammount of time when the latency is to high. Like you can do with speedfusion with the latency cutoff.
