Feature Request - Customize SF handshake port in IC2
Hello Team,
Customize SF handshake port is not supported by IC2 at the moment.
When will this be added in ic2?
Thank you.
@rocknolds
Please refer to the answer given by James Hedden here.
The requested feature is currently not available or in the upcoming 2.8.3 release.
Hello @JamesPep,
In relation to the comment at the URL mentioned by @sitloongs
Is it possible with combined future FW releases & IC2 updates that an alternative/secondary port could be custom defined while leaving the default handshake port intact?
Happy to Help,
Marcus :slight_smile:
Hi Marcus. What situations have you found that would benefit from a 2nd active handshake port?
Hello Martin,
Honestly none. The situation we are forward thinking of is where there may be a future client that wishes to define all port # usage or has an existing firewall using that port #, so a secondary handshake port # then would be useful. At the moment we have no need, it is just an idea for the increased flexibility of the Peplink/Pepwave range.
Happy to Help,
Hi Rocknolds,
SF handshake port customization has been added in the latest 2.8.4 release, and can be found on the device details page.
many thanks for the update @JamesPep
