Fast response load balancing algorithm
I am interested in knowing more about Fast Response algorithm and the release date.
Hi Houtaham,
The Fastest response Time algorithm will be implemented in Firmware 7.1 (currently in Beta) and works as follows:
when a network session is created, the first outgoing packet of that particular session is duplicated to all the available WANs.
When the first response is received from a remote server, any further traffic for this session will be routed over that particular WAN connection for the fastest possible response time.
If any slower responses are received on other connections afterwards, they will be discarded.
Thanks for your response, I am wondering the fast response algorithm is suitable for the occasions in which the reliability after ISPs are vital. is it a good understanding?
For short is β€œYes” as the traffics forwarding is depend the responses from the ISPs.
