I just started using my Pepwave Surf and it seems to be working well for me
What is a good starting point for the fall over settings for a Cellular?
The Cellular/Mobile Internet WAN default settings should work well for the fail-over.
Possible to let me know any other specific WAN fail-over requirement that you are looking at ?
Thank You
I have a Pantec UM-150 USB modem on the Verizon Network that I wanted to use as backup for WiFi. I do not know what settings to use.
