I want to setup a MAX BR1 Pro 5G in the following configuration:
WAN service on WAN ethernet port. It’s a good service, but metered and becoming expensive.
Cellular Sim in slot.
WAN is primary, Cellular is Secondary.
I want it to failover to Cellular if either of the following reaches:
a). the WAN goes down (or dramatic drop in quality).
b). I consume more than X GB on the WAN.
b is the part that I’m not sure of. I believe that this is what the “bandwidth allowance monitor” is used for.
A 2nd / alternate configuration would be to just throttle back the bandwidth of the WAN. ie only allow 50mbps on that interface. does peplink have an option for that?
