Every once and a while the peplink is not there. (moving locations, crashes, cat chews on the power cable, whatever the reason) so at that point I start up my backup dhcp/dns so that my internal machines can still function and talk to each other.
Problem is I have to keep a dhcp.conf file up to date to match what’s in the peplink.
Would be helpful if there was an export button on the static DHCP, (or entire setup) into a dhcp.conf format:
eg:
host vb-fedora16 { hardware ethernet 08:00:27:E5:1E:02; fixed-address 172.29.0.242; option host-name “vb-fedora16”; }
Then I can just keep this in a text file when I need to start up the backup DHCP server. If not dhcp.conf format… a csv file would be useful then I can write some script to translate it.
