Is it possible to exclude 1 wan from qos?
i want this link dedicated to a specified subnet via the outbound policy.
Thanks.
Joco
Thanks.
Joco
QOS is a global setting so it will apply to all WAN interfaces.
which prevails? Outbound policy or Qos?
For the condition that having Outbound Policy and Qos. The traffics from specific subnet will be loaded into the WAN link according to your Outbound Policy. For example source 192.168.1.0/24 will be load into WAN1 based on your defined policy. If this subnet carries voice and data traffics, then voice traffics will having higher priority (if you defined voice has higher priority).
Hope this help.
