Error: configuration file not accepted
Hi i have the following pepwave cellular router.
Model: Pepwave MAX HD4
Product Code: MAX-HD4-LTE-US
Hardware Revision : 1
Firmware: 7.1.0 build 3433
PepVPN Version 7.0.0
Modem Support Version: 1022 (Modem Support List)
And i want to send the configuration file to a remote location where
we have the following pepwave cellular router.
Model: MAX HD4 LTE with MediaFast
Product code: MAX-HD4-MFA-LTE-US-T
We are getting error message saying : Error: configuration file not
accepted.
This configuration file is generated by a different product model.
Is there a way to change the config and upload in our remote router?
@sureshkc
Both the devices are different model, you can’t direct upload the configuration download from HD4 to the HD4 MediaFast.
You can contact Peplink local partner for assistance or open a support ticket to support team and see what they can help this.
