It would be useful to have the USB port enabled by default out of the box. On bpl’s, it is disabled.
Having the USB port enabled by default enables zero touch config by inserting a usb modem into the device.
- insert modem
- unit connects to internet
- unit downloads it’s config from master
- done
If the usb port is not enabled, it requires connecting to the device, need a cable etc…
