Earthing on a Peplink Balance One Core
I noticed that there is no visible earth point - on the router. Does the cable holder act as an earth point?
There is no grounding screw for Balance One/Balance One Core. If grounding is important for your environment, you need to consider to go for other model such as B310.
Thank You
