Hello @cover & @vtjballeng,
What is the real reason you want inbound failover on a domain name? If it is only to access your local security cameras (and we hope you have them on an isolated VLAN from the rest of your network), then there are alternative to making this work using the services and features available from Peplink|Pepwave. We are finding less and fewer reasons nowadays to be opening ports inbound to any network.
On some of the higher end Peplink Routers (such as the Balance 380, 580, 710 & hight plus the SDX & EPX), the router can act as a domain authority updater, giving the options for inbound load balancing and failover much like the outbound services of the routers. From what we can recall, this feature has been available in the higher end routers since pre firmware 6.x.x and is often underestimated in its power and abilities, we use it where an organisation needs to have inbound load balancing and failover for servers within their data centres or operations facilities.
This image shows the options that can be configured, image is from Firmware 8.1.0 in a Balance 580.
In other Peplink|Pepwave routers that do not have the above feature, we are setting up clients with a FushionHub in the cloud (most of these we host on behalf of our clients), we then created a SpeedFusion link with the clients Peplink|Pepwave router. On the clients Pepwave|Peplink router we close all incoming ports and have no DDNS running. The FusionHub sits behind some secret stuff protection (ie firewall) within the datacentre, the customer is assigned a domain name that points to the FusionHub’s public-facing IP.
Not only do we use this for customers who want to access remote cameras, though we also use this for customers who operate SIP/VoIP PBXs at their sites and other inbound services that need the clean failover of multiple connections. We leave all connections running with equal Priority 1 on the router and manage all traffic and failover to backups using VLANs and outbound policies.
There are many previous posts within the forum on using everything mentioned above that can help you achieve these results.
Happy to Help,
Marcus
