Hello
I have My Main Cisco,and have /21 network from ISP-1 routed to the input for Cisco router and the output connected into WAN1 of Peplink the LAN its connected to clients and WAN2 WAN3 for Backup links ISP-2,ISP3,
the IP connection between users and Cisco im use private IP/30 of between user and Cisco and I route /28 or /29 IP to the client in the Cisco and Peplink ,
the problem I have Multiple private IPs for each user with mask of /30 , what is the correct IP I must Use it on the peplink , now fail over its not work and the peplink work as Bridge.
When I’m use on public IP and all user connect through it its work fine but i can’t route them IP. (( They must Be connected directly into peplink ))
Thanks.
