which of the following max supports cellular wan through passtrhough mode?
max-on-the-go
max BR1
max BR2 ip55
max HD2
max HD4
The MAX BR1/BR2 support IP passthrough mode.
Dear thank you very much for the help really appreciable
can you help me with few more questions
which action cannot be performed via the balance 710’s LCD panel
viewing the event log
checking high avaialbility status
setting wan1 port physical speed
monitoring wan1 throughput
checking speedFusion profile connection status
ANS:
A device with the same device stting but witha a different serial number is detected
HD2 does not have a license to be managed by the router utility
there is an ip conflict
max hd2 has replaced a max OTG using the same ip address
you need to delete the conflict profile to proceed
ANS:
In a balance/MAX web admin,if the sppedfusion graph indicates packet loss,which direction is it occuring
both direction
uplink or downlink
uplink only
downlink only
ANS:
for surf on the go which is the best description for the "connec to any open mode AP"option under wifi wan setting
connect to any open mode ap with stromgest signal
connect to any open mode AP
connect to AP
ANS:
for what reason should force UDP encapsulation when defininf an ipsec profile?
to get throguh a NAT connection
to increase security
to gain higher throughput
to increase privacy
none of the above
ANS:
while using pepvpnbehind the firewall,one needs to open the incoming ports of
tcp port 32015
udp port 4500
tcp and udp port 4500
tcp port 4500 and udp port 32015
tcp port 32015 and udp port according to dual port"default"or custom setting
ANS:
which peplink product can you use to configure social wifi hotspot
Balance
Incontrol
Mediafast
FusionHUb
ANS:
what options are available to help the AP controller and pepwave aps Automatically discover each other
Multicast DNS
DHCP
DNS
TFTP
A properitary peplink protocol
ANS:
what is the ip rating of the AP one Flex 300M devices
ip54
ip55
ip66
ip67
ANS:
which balance model can control 200 units of AP One at minimum cost
Balance 380
balance 580
Balance 710
Balance 1350
ANS:
Ina 3-site fully mesh vpn deployment secanariohow many internet lines at minimumare required in total to
support speed fusion Hot failover and Bonding at all locations
3
4
5
6
ANS:
which of the following best describes the priority algorithms
traffic coming from same machine will be presistentlyrouted through the same wan connection
traffic will be proportionally distributed among available wan connections
traffic will be routed through the specified wan connection,regerdless of the connection health status
traffic will be routed throguh the health wan that has the highest wan priority
traffic will be routed throguh the health wan conection that is selected in the connection field and that has the most available downlink bandwidth
ANS:
what type of dns records are supported by the balances bulit in authorative dns server
SRV
PTR
AAAA
A
ANS:
________________________________________________________________________________________________________-
Dear Tim sorry for bohtering can you help me above the questions please
It sounds like you are taking the PCE exam Please go over all of the training modules very closely. All of the questions can be answered via the training modules, user manuals, our website and Knowledgebase.
OK DEAR THANKS
I m actually trying for the exam. i have almost gone through the modules but only these few questions if you can help me it will be very helpful
Sorry, but simply posting the answers to these questions defeats the whole purpose of the exam.
ok man thanks a lot i can understand
we can be in touch in skype as well
my skype id is nawazbasha
Can you please help me,
Which Balance model can control 200 units of AP One at minimum cost?
Select one:
a. Balance 380
b. Balance 580
c. Balance 710
d. Balance 1350
