DOME PRO LR Maritime
In the maritime industry, reliable connectivity is essential for operations, safety, and crew welfare. The Peplink Dome Pro LR is a high-performance, single-cable 5G antenna designed to provide long-range, high-speed connectivity for vessels operating offshore. But is it the right solution for your needs? I break down of my pros and cons of using the Peplink Dome Pro LR in maritime environments.
Pros of Peplink Dome Pro LR for Maritime
  1. Single-Cable Simplicity
    The Dome Pro LR uses a single Ethernet cable (PoE-powered) for both power and data, simplifying installation and reducing the need for additional wiring. This is particularly beneficial for vessels where space and cabling complexity can be an issue.
  2. Long-Range 5G Connectivity
    With a powerful, high-gain 4x4 MIMO antenna, the Dome Pro LR is optimized for picking up 5G and LTE signals over long distances. This makes it ideal for yachts, commercial ships, and offshore vessels operating far from shore but still within cellular coverage.
  3. IP67-Rated Weatherproof Design
    The rugged, IP67-rated housing ensures protection against harsh maritime conditions, including saltwater, strong winds, and heavy rain. This durability makes it well-suited for permanent outdoor installation on a vessel’s mast or deck.
  4. Seamless Integration with Peplink SD-WAN
    When paired with Peplink’s SpeedFusion SD-WAN technology, the Dome Pro LR can bond multiple connections—including 5G, Starlink, VSAT, and Wi-Fi—to create a more stable and resilient network. This is a significant advantage for ships requiring uninterrupted connectivity.
  5. Remote Management and Monitoring
    Peplink’s InControl 2 cloud-based management system allows remote monitoring, configuration, and troubleshooting. This is valuable for fleet operators who need to manage multiple vessels from a central location.
Cons of Peplink Dome Pro LR for Maritime
  1. Limited to Cellular Connectivity
    While the Dome Pro LR excels at 5G and LTE connectivity, it does not directly support VSAT or Wi-Fi-as-WAN. This means vessels operating outside of cellular coverage will require additional connectivity solutions, such as Starlink or VSAT.
  2. High Cost Compared to Standard 5G Routers
    The advanced technology and marine-grade durability come at a premium. The total cost, including installation and potential SpeedFusion licensing fees, can be high compared to standard 5G modems. However, for vessels requiring reliable long-range 5G, this cost may be justified.
  3. Requires Strategic Placement for Optimal Performance
    Since the unit is designed to be installed outdoors on a mast or high point, placement is critical. Poor installation can lead to suboptimal signal reception, reducing its effectiveness in picking up distant cellular networks.
  4. Potential Data Costs for Heavy Usage
While 5G offers high-speed connectivity, maritime data plans can be expensive, especially for large commercial operations or streaming-heavy usage. Without proper data management (such as SD-WAN traffic shaping), costs can quickly add up.
The specs list wifi as wan, that is missing?
