Domain name rule clarification
I just need a quick clarification of wildcard in domain name rules. If I enter a rule for apple.*
www.apple.com matches
www.apple.com.akadns.net matches
www.itunes-apple.com.akadns.net ???Does this match the wildcard???
In case anyone else is looking for this answer, I found it under a special menu in the DNS proxy…
Yes, the help text explained that.
Just for your info. http://www.itunes-apple.com.akadns.net/ will not be matched if your domain rule is apple.*. You need to define a domain rule with itunes-apple.*.
