Does the peplink balance support any usb wifi adapers – like this one – http://www.simplewifi.com/alfa.html
or any other model WLAN adapter (only requirement is external antenna support) …?
Ben
Ben
Hi Ben- The USB ports on the Peplink Balance routers only support cellular modems as a WAN interface at this time.
Ben,
The usb port is for 3G/4G support only. USB WiFi would not be compatible in the usb port.There is a list of supported modems on our knowledge base which can be found using the enclosed link.
