Does Peplink Balance Require Static IP on WAN Connections?
#1
When it comes to requirement for WAN connections, we need to consider whether it is for outbound or inbound load balancing.
  • For Outbound Load Balancing:No Static IP address is required. All WAN connections can have Dynamic IP only.Example:
    wan_ip_outbound
  • For Inbound Load Balancing:At least two Static IP addresses, each on a separate WAN connection, are required.As Peplink Balance will act as an authoritative DNS server of the domain name, at least two WAN connections are needed, and a Static IP is required on two of these WAN connections.
    Example:
    wan_ip_inbound
Inbound access - newbie need some infomration-
