Docker logs on Peplink Max BR2 Pro
We are currently testing the Docker feature with firmware version 8.3.0 build 5229 and have encountered some issues.
Specifically, any straightforward Docker container running a process in daemon mode is failing and exiting rapidly.
We are eager to find out more about the limitations or potential issues related to the Docker feature in this firmware version.
Could you kindly direct us to any logs or documentation that might help us starting using docker on peplink devices?
Thank you,
Tanguy
Got an answer from Peplink support that the error was: "Unsupported image platform “linux/amd64”
MAX BR2 Pro is ARM64.
Would be nice to have more docker logs.
Tanguy
