Hi may i ask the dns proxy function at peplink balance is support how many type of dns record.
Hi Yeohsoonkian,
Yes, Peplink Balance supports DNS Proxy for LAN clients. You can find this under Network > LAN > Network Settings.
It’s also possible to manually adjust the TTL value, if you would like to do that.
