Hi Folks,
Not sure if there is a way to do this but here goes.
Is there a method to disable the firewall on the pepwave max. I have a customer who is putting in his own dedicated firewall on the lan side and does not need to have a double firewall running. He’s only using the 3G/4G link for telemetry and control at a wind turbine station and does not use the WAN port.
in Advance
