The dhcp server in our balance 710 is having some trouble. We had a power failure in November and dhcp did not work at all after it. Yesterday, I updated it to version 6.3 to see if that would solve the problem and I thought it did. But I am seeing in the logs that it’s handing out IP addresses to some clients and expiring them in 1 minute causing them to dhcp again, thus losing connectivity for a while.
Possible to share the DHCP setting & event’s logs here for us to further investigate the issue ? Else if info is sensitive to share here, please open a support ticket for us to further investigate the issue.
https://contact.peplink.com/secure/create-support-ticket.html
Thank You
I’ve created the support ticket on it. Thanks!
