We’re testing the “device IP settings” by importing a csv files, but it don’t seems to apply.
On a hardware IC2, we’ve got a bulk configuration, and, if I understand, the device takes first the config and then the IP settings is applied. For the config, it works well, and the device receives the IP of the template, but the IP is not updated then. Here’s a sample of the csv:
SN,LAN_NETWORK_LIST,LAN_MEDIA,LAN_STROUTE1,DHCP_SERVER,DHCP_SERVER_LEASE,DHCP_SERVER_NETMASK,DHCP_SERVER_POOL_START,DHCP_SERVER_POOL_END,DHCP_LOG_ENABLE,DHCP_SERVER_DNS,DHCP_SERVER_WINS,DHCP_OPTION_15,DHCP_RELAY_OPTION_82,DHCP_RELAY_SERVER,LAN1_VLAN_ID,LAN1_NAME,LAN1_NETWORK_LIST,DHCP1_SERVER,DHCP1_SERVER_LEASE,DHCP1_SERVER_NETMASK,DHCP1_SERVER_POOL_START,DHCP1_SERVER_POOL_END,DHCP1_LOG_ENABLE,DHCP1_SERVER_DNS,DHCP1_SERVER_WINS,DHCP1_OPTION_15,DHCP1_RELAY_OPTION_82,DHCP1_RELAY_SERVER,LAN2_VLAN_ID,LAN2_NAME,LAN2_NETWORK_LIST,DHCP2_SERVER,DHCP2_SERVER_LEASE,DHCP2_SERVER_NETMASK,DHCP2_SERVER_POOL_START,DHCP2_SERVER_POOL_END,DHCP2_LOG_ENABLE,DHCP2_SERVER_DNS,DHCP2_SERVER_WINS,DHCP2_OPTION_15,DHCP2_RELAY_OPTION_82,DHCP2_RELAY_SERVER
XXXX-XXXX-XXXX,192.168.1.1/24,auto,enable,84600,255.255.255.0,192.168.1.10,192.168.1.20,yes,
YYYY-YYYY-YYYY,192.168.2.1/24,auto,enable,84600,255.255.255.0,192.168.2.10,192.168.2.20,yes,
Is there something I’ve missed ? I’ve seen nothing interesting in the log. I’ve seen a “preserve ip” option in the BC, but whre can I configure it ?
David
