Dear Guys,
Need to know what would be the maximum experimental distance between the following devices so that they can see each other and repeat a good signal:
AP Pro Duo <==> Device Connector IP55 AP Pro Duo <==> Device Connector IP67 AP Pro Duo <==> Device Connector Rugged
Can you share what antenna you are using and how of the deployment?
We’re gonna use the default antenna on the device. 8dbi for AP Pro Duo and 5dbi for rugged.
Hi Hootan,
Sorry to keep you waiting. I will continue chase for the answer internally.
This is the engineering estimation - AP Pro Duo <==> Device Connector Rugged - 400m. Anyway, the actual environment may be different since it may affect by environmental factors. I suggest doing survey before the deployment.
Noted. That would be fine.
