As the title states, is it possible to deploy Fusion Hub in a Docker container, specifically one running in an AWS EC2 Linux instance? I already have a beefy EC2 instance and for this application spinning up a second one doesn’t make a lot of sense. If I could leverage the current one I have this would be great, but I don’t see any information on how to do this online.
FusionHub is not currently available as a docker container.
Well… Technically you can run a Linux OS inside a docker…
But you’ll be on your own getting FusionHub OS to run on docker since no one has done it… yet!
Maybe you should be the first to publish how to
