Hi all,
I would like deploy Incontrol in my local VMs and I have question. Please help me make me clearly
- Can I deploy im my local Vms?
- What’s license I have to buy?
Thanks all
Hi all,
Thanks all
Hi @hoangphuong2308,
Yes you can. Our InControl Virtual Appliance is compatible with VMware ESXi and Microsoft Hyper-V. There is an installation guide available > Here < and the appropriate files can be downloaded from > Here <
This really does depend on your deployment requirements. I believe you can start with a 100 device licence, allowing you to manage up to 100 devices on your InControl Virtual Appliance (ICVA). Additional licences can then be added, as necessary in blocks as required. Your local > Peplink Certified Partner < will be able to help you decide which is the best option for you and your requirements.
Hope this helps,
Steve
Hi Steve,
Thanks for your information.
I will contact partner of Peplink in my region for buy license for my business
