Dashboard not retaining WAN Priority (Balance 305 8.3.0 )
I keep moving the VZ Wireless B274 connection to slot 3 but it keeps going back to #1 after I release (from drag and drop). In most everywhere else in the system when a change is made, I am asked to Apply the change but that doesn’t happen here. What causes this to retain #1 position?
For each Connection I want them all Connected but I want most traffic going to T-Mobile and Starlink. I use Outbound policies for Smart TV’s but not for the rest.
(Side note, how can I move my Outbound policy from a Balance 305 with 8.3.0 to Balance 580 with 8.3.0? No peplink service plan.)
Thanks in advance!
I’ll let someone else respond to your principal question. Your understanding of “how it is supposed to work” is correct. That’s a strange one.
As to your 2nd Q, there is a conversion utility available to Peplink Partners that can convert the config file from a 305 to that for a 580. Your Peplink Partner can help you with this. (This utility will not work with many other conversions but I think it will between 305 and 580.) If you don’t have a Peplink Partner with who you work send me a PM – I’ll be pleased to help you out.
  • Rick
I’ve set the Standby State to Remain Connected thinking that may have something to do with it, but it does not.
