“I’m trying to connect my iPad, which is running the CZone 2.0 app, to the CZone system on my boat. The CZone is connected via Ethernet to a Peplink BR1 Pro 5G router, which also has SpeedFusion enabled. I need assistance with completing the setup so I can access the CZone system remotely from my iPad.”
Thanks for the help
Ahoy there!
Are you wanting to remote in using the CZone App?
Then you would want to VPN into your vessel and connect that way.
Alternatively, look at products like Sentinel or other systems that interface with CZone/NMEA2000 for remote monitoring.
