Hello
Could you please advise what the current Firmware version is for Pepwave Surf On-The-Go devices and where I can download it as it doesn’t seem to appear on the list of current firmware downloads.
Ashley
Hello
Ashley
Hi ashleyh,
The firmwares for the Pepwave Surf On-The-Go are certainly still there, but they are easy to miss on the firmware downloads page.
You can find them on the very bottom left of the firmware downloads page.
Direct link: https://www.peplink.com/support/downloads/device-connector-and-surf-otg-firmware-and-user-manual/.
Hope this helps!
Many thanks.
Will this firmware version make PepVPN connections with Balance 20 firmware version 7.0.1?
Ashley
This should be fine.
I have tried updating the firmware and when I go to extract the file it says that the file is unknown or broken. How can I fix this. Pepwave otg
Blockquote[quote=“Joey_van_der_Gaag, post:2, topic:11885, full:true”]
Hi ashleyh,
Hope this helps!
[/quote]
Thanks for your sharing. I could find needed firmware.
Yes I have them downloaded. But when I go to unpack them it says that the file is broken or damaged, if I try to install it the way that it is it says that the file is to big.
