CPU History bandwidth usage
Hello! Happy Peplink Balance One Core user, is there a way to log CPU history and bandwidth usage so that this data can be compared in a spreadsheet, for instance to spot bottlenecks?
Maybe @MartinLangmaid can help?!
Yes. Two ways, you can use SNMP to do this by installing something like PRTG or you can use the device API. Both methods are more complicated than you will want them to be, SNMP will be the easiest approach I would suggest.
Thanks!
