Hello Friends,
I have two peplinks Balance 710
the main one is Hardware Revision 3
And the Backup one is Hardware Revision 1
Is it possible to convert a configuration backup file from Balance 710 Hardware Revision 3 Firmware 8.3.0 build 5200
to Balance 710 Hardware Revision 1 Firmware 6.3.4-build3613
Harel
Have you tried to downgrade the Balance 710 Hardware Revision 3 to 6.3.4 , and then exporting the config? You might have to downgrade it in several order 8.2 , 8.0 , 7 , 6.3.4
You could also just keep the pages open between the two and manual add in the settings.
Why are you trying to apply a newer config to a older 6.3.4 fw?
